The scale compensation feature doesn't work
negroclarito
Post by negroclarito »
Hi everyone...
Someone else has the same problem?... even I have the SCALE COMPENSATION checked in the layer settings... when I scale a layer, lines are not scaled :shock: .
I don't know if in Anime Studio pro 10 I need to do anything else to make it work... because in other versions it worked fine.
Re: The scale compensation feature doesn't work
It's working here. Can you share an anme file?
negroclarito
Here it is...
It's a simple file.
https://dl.dropboxusercontent.com/u/16959006/Lupa.anme
I don't have any script installed.
What happen with the 10 version!!. It has many bugs!!!. And now when I updated to 10.1 many characters I had made I had to rebuild some parts because some bones and vector points went crazy.
Thank you for your help Selgin.
I'm on 10.1 and it works as expected. Have you tried 10.1?
negroclarito
Ok, I've solved it!!. I install the software again (the third time I reinstall this week) and seems to be solved.
I don't know what happened beause I have no scripts installed and I have the last Mac OSX in my computer.
I have reported some bugs to Anime Studio support but they had never answered me (instead of this they send me thousands of advertising to my email). SmithMicro support seems very bad to me. I'm not happy with them :( .
I was buying Anime Studio from 6 version and the only answers I get to my problems is here in the forum and with videos in youtube like yours.
Thanks for your reply Victor.
negroclarito wrote:Thanks for your reply Victor. I have reported some bugs to Anime Studio support but they never answered me (but int eh other hand they send me thousands of advertising). SmithMicro support seems very bad. I'm not happy with them :( .
I'm working as beta tester and also had the luck to know them personally and see how they work. They work hard and very seriously finding and fixing bugs, I'm very sure about that. I'm sorry you have a bad experience. I know it's not the best solution, but in the future, if you have a problem with the software, please write it here in the forum or send me a PM and I will directly report it in the official bugs database.
I'm on a pc right know. I won't have access to a mac until next week, but I can try it next Monday. Anyway, I have noticed sometimes the scale compensation preview doesn't work well when you have the GPU acceleration activated. Does it work when you render it? or when you uncheck the GPU acceleration?
negroclarito
I don't know what happened because I have no scripts installed and I have the last Mac OSX in my computer.
OK, next time I will ask you directly.
Thanks for your quick reply and help.
negroclarito
I'm creating an animation series with very complicated characters and many actions. Maybe was something wrong with something.... I don't know.
BTW... Anime Studio should have some tool so that can change line width, line color and fill color in all layers into a group or bone layer. It could be very helpful to change all the colours of a character that has different layers. There was a script for that but know doesn't work in last version of AS.
I'm glad you solved it :)
negroclarito wrote:Anime Studio should have some tool so that can change line width, line color and fill color in all layers into a group or bone layer. It could be very helpful to change all the colours of a character that has different layers. There was a script for that but know doesn't work in last version of AS.
Actually, you can do that using Styles.
negroclarito
Using styles only can change layer colours one by one. What I mean is a tool you can use to change for example... the line color for ALL layers.
There was a script for that. You could select one color line and had the option to change that color in all lines in all layers. Also you could select one fill color and change that color in all child layers into a bone layer, group, switch layer at the same time.
With the line width the same. Even using styles you need to change them one by one.
Some tool like that would save a lot of time.
