Render problem -- frames skipping?
Seifo
Post by Seifo »
I've been using Anime Studio for a year or two now, and I'm still really impressed by its capabilities. Just recently, though, as I've been exporting animated clips at 24 FPS, I've run into a small issue.
See, I have a character with a cape flying at high speeds -- flying so fast that I want his cape to flap back and forth in a 2-frame cycle. But when playing back the uncompressed AVI I exported, some of the frames are seemingly skipped -- like instead of a continuing pattern of 1-2-1-2-1-2-1-2, it goes kind of randomly, something like 1-2-1-2-2-2-1-1-2-1. It can't be just because it's slow playback on an uncompressed AVI, because I can watch frame-by-frame in Sony Vegas and confirm that it's a problem with the actual video. Any thoughts? I have AS 10.1.
Re: Render problem -- frames skipping?
First, try disabling multi-thread rendering.
Seifo
Post by Seifo »
Okay, just tried it, and it didn't work.
Do you have an AS file that shows an example of the problem? If it does not show up for someone else, it may be a problem with your system/install/etc..
Seifo
Post by Seifo »
Here you go. The red box is flashing to the left and right on a 2-frame cycle. It plays fine in Anime Studio, of course.
https://app.box.com/s/ahb9gyvattuy1dfqvcvz
Okay, it's not just you. I am also seeing duplicate/dropped frames with uncompressed AVI. There is something awry here, but there's also a way around it.
I assume you are using the same output format I tried first:
Instead, use this:
And then select uncompressed:
Hopefully this works for you as well. :wink:
Seifo
Post by Seifo »
Well, whaddya know -- it worked!! :D Thanks a lot for the help, synthsin. I think I'm gonna like this forum...
Glad it worked for you. I've reported the problem to the developers.
Are you on XP?
I am, and the developers think it may only be an issue on XP.
Seifo
Post by Seifo »
Interesting... :? No, I'm on Windows 7 Professional 64-bit.
Thanks, I'll let them know.
Seifo
Post by Seifo »
You're welcome. Just let me know if you need any other info. Thanks again for the help! :D
