conflict on 4:3 screen
Tidou
Post by Tidou »
Not a bug, but conflict on 4:3 screen.
Perhaps put Beginner's Mode - Character Wizard - Library in menu :?:
sbtamu
Re: conflict on 4:3 screen
Post by sbtamu »
Try increasing your monitors resolution.
Sorry for bad animation
Tidou
Post by Tidou »
I use 1280x1024 native resolution.
But yes, you're right : monitor supports higher resolution ... but scrolling with mouse is required.
Lebostein
Post by Lebostein »
Same problem here. I am working with a MacBook with 1280 x 800 pixel.
At the moment you can't ignore that! Most of the laptops at the moment using this solution or similar. The age of the high resolution displays has just begun and only few people in this world have upgraded to new hardware yet.
KSimon
Post by KSimon »
Yes - this is driving me crazy! My resolution is the highest available for the monitor - using on a laptop right now(1366x768).
I guess the solution is an external monitor? I wish there was a way to just disable and remove the beginner mode option.
KSimon
Post by KSimon »
Found a work-around: Undock the program window, then click and pull the right vertical frame to resize larger. That will move the icons so you can use them.
