how to correct this animation ?
labonneanime
Post by labonneanime »
hello yoobah hello all
i have to correct this animation
http://yoursteff.lautre.net/animation-studio/
you can get there
in fact i did binding points to bones but there is a lot of deformations :(
pleaz advice of what is wrong and so what to make
thanx a lot
regards
stéphane
Droxon
Re: how to correct this animation ?
Post by Droxon »
The problem is that the bone strengths are affecting the whole character, if you are working with bone strengths i'll recommend you to use the flexi binding feature.
I did it for you: (still needs fixing i just added the flexi binding)
https://www.dropbox.com/s/5t710vfs1jl3h ... .anme?dl=0
If you are working with points (bind points) well... there are many techniques for this, but if you want good deformations you have to use smart-bones to fix them.
You are also getting some weird deformations in your animation because of the way you are moving(translating) the bones. (you should only rotate them, unless you know exactly what you are doing)
You can find some very useful tutorials here:
http://anime.smithmicro.com/tutorials.html
labonneanime
hello droxon
thanx a lot ! i go try with smart bones so. thanx for the example
and have a good day/evening
regards
Poptoogi
Post by Poptoogi »
Hello Labonneanime,
As Droxon said it's a matter of the bone strength being turned down. Here is the same file with the bone strength turned all the way down and a simple walk cycle added to it. Nothing else was changed other than the bone strength but as you can see the character move a little smother. Some points are not bound correctly as you can see by the bottom right of the shirt but that should be an easy fix! Hope this helps!
https://www.dropbox.com/s/zm5gndqke9s6u ... .anme?dl=0
https://www.dropbox.com/s/k8uwa0t8ghb7t ... 2.mp4?dl=0
Practice random acts of kindness and senseless acts of beauty! Pause, consider, do! I dare you!
labonneanime
hello guyer93 !
oooooops ! i didn't saw your post since last month. pleaz accept my apologies !
so then i am at parents home actually and i will be back to town tomorrow !
thanx a lot for help, i will try what you told
regards and thanx
labonneanime
hello guyer
thanx a lot for your help
so then just avoiding bones strength ? i have to test it soon ! thanx a lot
regards
