How to remove white background when I install
pn2002
Post by pn2002 »
Please help me how to remove white background when I install anime stuido 10.1 on laptop Graphic card onboard 358MB, ram 4GB, Dell studio T8100 and when I add new vector layer and it appear white background as below pictures.
But when I install anime studio 9.5 it work OK, (not appear white background) Please don't mention my grammer English, Thank you so much !
_________
pn2002
http://akstudio.vn/vi/wedding-planer-hc ... laner.html
Re: How to remove white background when I install
Disable GPU acceleration.
Sorry, I'm not sure I understand your request. Are you asking how to change the background color?
In the image you posted, that off-white background display color should be normal for ASP 10. (It's same as my default display color.)The color is slightly off-white by default to make it more obvious there that is no actual background there. When you render the image, the region that's off-white will be transparent.
If you just want to change the display bg color, look under Preferences>Editor Colors, and then change the Background color. Note that this only changes the display bg color. This color does not (and should not) appear in the final rendered frames. I can see how in some situations, it might help to make the bg color different to make it easier to see fg elements when animating, or if you're going to use chroma keying, or maybe you just want to darken bg to make the display easier on the eyes.
If you want to render a solid color in the in background, you'll need to create an element that fills the screen. I just use a solid rectangle and set it to the color I want. If you want the background to be transparent for compositing purposes, just leave it alone--it will render transparent assuming you use an image format that supports transparency or an alpha channel.
G.
