Layer visible and invisible check doesn't work
evma96
Post by evma96 »
When I check a Layer on the first frame for invisible and then check the layer on frame 100 on visible the layer still is invisible? how can that be?
See the problem in the Video in the google drive link below:
https://drive.google.com/file/d/0B3esYP ... sp=sharing
drumlug13
Re: Layer visible and invisible check doesn't work
Post by drumlug13 »
Do you happen to have layer visibility changing in a Smart Bone for a body turn?
If you have Layer Visibility or Layer Ordering set in a smart bone action it will not let you change it in the mainline.
Adam
evma96
Post by evma96 »
ahhh yes that's it! Thanks for the hint !!
