Does anyone have suggestions on how i might go about doing a 3D page turn effect in AS?
I need to do this several times while panning the camera across products in a catalogue.
Cheers
D.K
Page Turn Effect Ideas?
My store on Renderosity:
Re: Page Turn Effect Ideas?
I just knocked this out in about ten minutes.
https://dl.dropboxusercontent.com/u/536 ... 0page.anme
Hi Wes, Fantastic work!!!!!
Unfortunately not the type of page turn effect I was referring to.
Check this:
http://youtu.be/lGXomkmx4aM
I need to be able to insert an image texture of each page onto the
page plane then after panning from one product to the next make the
page flip or roll towards the camera. I can do this easily in Lightwave
3D but the render times for 3D are a nightmare.
Cheers
D.K
Check this:
Cheers
D.K
Hi Wes,
WOW! How did you get the bones aligned and animated on the z axis?
D.K
D.K
DK wrote:Hi Wes,
D.K
Really cool thread!
- jezjones29
Here is another option: http://www.animestudiotutor.com/shared_files?id=165
It only uses rotate layer (Y).
It may not look at good as other page turns, but it's easy to setup.
Shadows could be added with other layers, but this shows the idea.
