Transparent Ouicktime movie not visible
uncle808us
Post by uncle808us »
I have a transparent QuickTime movie I am importing to AnimeStudio Debut10 but it shows up in the layer list but there is nothing on the screen in the animation, I can't figure out what I am doing wrong. I would appreciate some help while I still have some hair left. (smiling) :oops: I have exported it from two different softwares but no luck seeing it.
http://uncle808s.blogspot.com
Re: Transparent Ouicktime movie not visible
Is Quicktime installed on your computer? Did you start AS in 32bit mode?
uncle808us
slowtiger wrote:Is Quicktime installed on your computer? Did you start AS in 32bit mode?
Yes Ouicktime pro. As for the start in 32 bit I don't know.What would that have to do with it? The movie is transparent and composites fine in iMovie but There is nothing showing in AnimeStudio 10 Debut.
jayfaker
Post by jayfaker »
What codec are you using?
uncle808us
png from Cheetah 3d as I said it will open in other compositing software. But not in Anime Studio Debut 10.
sbtamu
Post by sbtamu »
The 64 bit version does not support QT. If you try and import a QT video, all you will see is a question mark. You will have to use the 32 bit version. Or use an avi video with transparent background which should work in the 64 bit version.
I believe this is a QT problem and has nothing to do with AS.
Sorry for bad animation
Yes, it's because QT is 32bit only.
