AS11 PSD problems
KuzKuz
AS11 PSD problems
Post by KuzKuz »
Hi. in AS 11 i have a problem with psd rigs. After editing PSD file in photoshop AS have Error.
If import this file in new scene - psd will work fine and AS import all layers, but update not working. In AS 10 update work fine. :(
GCharb
Re: AS11 PSD problems
Post by GCharb »
Works fine with latest Photoshop here, what version are You using, and can You share the file, so We can have a look at it?
KuzKuz
Post by KuzKuz »
Photoshop CC 2014.
Anime File Source
I Paint and keep layered model in Manga Studio lip File, and when i need to edit layer i must edit in Manga first,
and then replace layer in Photoshop, and in Photoshop i apply Color Lookup Adjustment layer (LUT file) to color correction.
Then editable layer in my AS model was crash. :( In AS 10 all work fine.
If Photoshop is using your Manga Studio file as a reference, and Anime Studio is using your Photoshop file as a reference, I can see that this workflow could provide problems... Both of these programs would probably be using temporary internal files in order to track edits, which could interfere with the official file formats.
KuzKuz
Post by KuzKuz »
Thanks, i understood how easy reproduce this problem. Need to create new layer (before last in order) in photoshop and merge with old layer.
Need add feature to change psd ID layer in layer settings. This will solve all problems with PSD. It was possible with scripts in AS 10, but not in AS 11. :cry:
Please give this ability.
