vector dissapear!
manzanimator
vector dissapear!
Post by manzanimator »
Hey, i have an issue. Well i am doing an animation. now i create a vector. ( rock for example). i draw my rock all seems ok. it apears there. now i am trying to insert my vector in a new bone layer that i create, and when i do my rock instantly dissapear. i use AS pro for some month and this never happened to me. don't know where is the probleme. how can i fix this?
willf
Re: vector dissapear!
Post by willf »
The rock's position on the vector layer might just be jumping around out of view of your workspace. Try zooming out a ways and see if it isn't off to the side somewhere.
Alternately, you could make the bone layer first, and make a new vector layer nestled inside it. Then create your rock in the vector layer, and now you won't have to put it in a bone layer afterwards. So you avoid whatever is causing it.
manzanimator
willf wrote:The rock's position on the vector layer might just be jumping around out of view of your workspace. Try zooming out a ways and see if it isn't off to the side somewhere.
thank you! Yes that was the issue. My vector was like 10 000 kms away from the screen! thank you :)
