PNG renders transparent background?
dssw
Post by dssw »
I have the background color set to white but when I render as .png's (for later sequencing in mplayer) the background of all the png files is transparent, how do I turn this off? I cant seem to find an option anywhere. Note: Preview and Render show the background, Export Animation doesnt.
Second Note: To sequence them in linux use a command like: mencoder mf://*.png on:fps=24 -o output.avi -ovc lavc -lavcopts vbitrate=400:vhq
Change vbitrate (variable bitrate) as necessary, depending on how complex the detail is.
Third Note: While typing this I managed to come up with a workaround by making a new layer with a white rectangle that takes up the entire screen and is the bottom most layer.
T
Post by T »
My test turned out the same... but I think your workaround is solid solution to the problem... if it is a problem.
"T"
One who makes no mistakes, never makes anything.
www.flyingmcdavidbros.com
Avalanche941
Post by Avalanche941 »
I have exactly the opposite problem! I can't get my background to be transparent!
"Good" thinks itself "good", but "evil" thinks itself "good" also. "Evil" thinks "good" is "evil", and vice versa. You think "good" is "good" simply because it is better for your welfare.
Rasheed
Post by Rasheed »
That the PNG sequence export delivers a transparent background is a normal behavior. PSD sequence export has that same property, I believe.
It offers the possibility to add a background externally. You can reuse a PNG sequence with different backgrounds or combine several PNG sequences and have different scenes with a limited number of animation clips.
So, in fact, you can save time if you use the transparency of the background to your advantage.
I think CinePaint is an excellent program for doing these kinds of manipulations. And as so many open source projects, it is freeware.
