Problems saving
madriver
Problems saving
Post by madriver »
Have an issue saving over the same file. Here's what happens:
1. save file
2. shut down program
3. restart program the next day and work on the same file
4. it refuses to save, says "the file may be marked read only or you may be trying to save to a read-only disk" HUH???
5. Have to save it under a different name
So now I have duplicates of everything I work on because it won't save over the same file!! I'm afraid to shut the program down at all because it might not save again!! :x
GCharb
Re: Problems saving
Post by GCharb »
Hello Mad, have you checked your permissions for that drive?
madriver
Re: Problems saving
Post by madriver »
Hi GCharb: just checked and yes, the permissions were not set for "full control". Thanks! :D
clipart125
Re: Problems saving
Post by clipart125 »
hi ! Me also had this error.I tried a lot of time but does'nt But after some time i just connect my pc to the net then automaticlly it resolves hahah :mrgreen: :mrgreen: :mrgreen:
I think you should try ! :!: :!: :!: Thanks !
PRIMAL MORON
Re: Problems saving
Post by PRIMAL MORON »
Should this happen again, i got a temp fix as well, it involves a process called com surrogate.
CTRL+ALT+DEL,
then go to task manager,
go to the full set of options and look under processes for Com Surrogate,
if you see even one version of it, right click on it and press "End task" or hit the end task button.
It's supposed to help with graphics (particularly with gpu related stuff and thumbnail saving for the files) but is very buggy and may cause some memory leak issues.
Simply make sure all com surrogates are gone from the list, but do not touch or end task to anything else.
Then close your task manager and try saving again. I have tested this on windows 8, 8.1, and 10. It occurs in Anime studio 10-11.3 (Pro tested, not sure about debut)
This may be a reoccurring thing, so keep that in mind.
Hope this helps,
-Matt
madriver
Re: Problems saving
Post by madriver »
Thanks Matt. This is helpful because one of the error messages had something to do with this com surrogate thingy, which I'd never heard of.
So far, changing drive permissions has helped but will add your fix too.
