how do i change the view settings for keys? AS 11
skygaz3r
Post by skygaz3r »
hello there!
i just started using AS11, before i have been using AS9.
i want the keys to be shown just like that "point/dot" not in that "length" thingy. using switch layer it´s in that length thing, but actually i like the simple "point" view more. is there a way to change this and set this by default?
sorry, my english isn't good ;(
drumlug13
Re: how do i change the view settings for keys? AS 11
Post by drumlug13 »
It must be Pill Key day for the forum :D
There's two discussions going on with this topic. The pill shape is indicating how long that vector layer in your switch is holding. It's the new visual indication of a hold key. So you can change that by checking the "Interpolate sub-layers" in Layer Settings > Switch Tab.
viewtopic.php?f=13&t=28724
Adam
skygaz3r
Post by skygaz3r »
well the interpolate sub-layer might show things as points, but it also does what the option is usually ment to do, it moves the point according to the changes i made on the several layers. well... and that messes up the animation a lot :(
drumlug13
Post by drumlug13 »
Your English is just fine :)
You are correct. The long pill shape hasn't changed the way AS animates. It is just the new visual indicator for hold keys in the timeline. I think you will find it very useful when you get used to it.
Adam
