[solved]Smartbone problem
gongor
Post by gongor »
I have been rigging this character 2 days now. Got some problem :( it was perfectly fine when in smartbone action but in mainline it's snapping from target bone weirdly like it's parented to my control bone. I have checked parents and other and stuff didn't find any particular problems :( any suggestion what might have causing this problem ? It was working about 2 hours ago but don't know what happened :( :?
Re: Smartbone problem
Smart bone problems usual occur when you have accidentally keyframed another bone in the smart bone action. That's the first thing I'd check. Unless you want the smart bone to control other bones, it should be the only bone keyed in the action.
gongor
Post by gongor »
synthsin75 wrote:Smart bone problems usual occur when you have accidentally keyframed another bone in the smart bone action. That's the first thing I'd check. Unless you want the smart bone to control other bones, it should be the only bone keyed in the action.
I have two body turn action by the way one is turning left other is right. Both are changin position of bones. What is the term of another bone ? one in different bone layer or a different bones in same layer ?
A different bone in the same layer.
gongor
Post by gongor »
synthsin75 wrote:A different bone in the same layer.
so its not possible to control bone position with smartbone :(
It is possible. That's why I said, "Unless you want the smart bone to control other bones." Are you wanting the smart bone to control your problem target bone? If not, the target bone should not be keyed in the action.
gongor
Post by gongor »
synthsin75 wrote:It is possible. That's why I said, "Unless you want the smart bone to control other bones." Are you wanting the smart bone to control your problem target bone? If not, the target bone should not be keyed in the action.
thank you answer
yea i want to move target bone in action :D how should i do this ? without that snapping
Well it looks like your smart bone is in its default rotation (the angle at frame zero) at frame 42 in your action. If that is true, then your smart bone is applying animation to your target bone without being rotated on the mainline. To fix that, you'll probably need to copy the frame zero rotation of the smart bone to that frame in your action, and then keyframe where you want the target to be (again, probably copying its key from frame zero to that frame in the action).
gongor
Post by gongor »
Wow it worked thank you so much :D
