Keyframe on frame 0 (solved)
ghostRadish
In one of my projects I have a keyframe on frame 0 that I can't find a way to remove. On frame 1 and without any keyframes, an image Is moved completely of place. I think it's associated with the keyframe on frame 0. Anyone know how I can fix this?
Re: Keyframe on frame 0
If you can post a link to the file I can figure it out.
ghostRadish
In Tutorial 4.3: Image Textures from the Tutorial Manual, there is an animal's body separated in frame 0 but when you move to frame 1 it's put together. How was that done? I think my problem is related to that.
ghostRadish
I don't have anywhere to upload it right now. I had a dropbox account, just need to find the login info. I'm really just curious now how they managed that trick with putting everything together automatically in the Image texture tutorial...synthsin75 wrote:If you can post a link to the file I can figure it out.
That is making use of the Offset Bone tool.ghostRadish wrote:In Tutorial 4.3: Image Textures from the Tutorial Manual, there is an animal's body separated in frame 0 but when you move to frame 1 it's put together. How was that done? I think my problem is related to that.
ghostRadish
Thank you. I must have used that somewhere along the way by accident.
Re: Keyframe on frame 0 (solved)
Glad I could help. If you hadn't mentioned that tutorial, I'd have never guessed that was the problem.
