is there an option like "real time playback"?
undo
Post by undo »
when is are lots of stuff on the screen, the playback slowers down to a lower frame rate.
But thats a problem because i cant see how fast it will be when rendered.
Its very difficult to get a good timing in the animation that way.
is there an option like in Maya e.g. which tries to hold the frame rate by dropping some frames in the preview?
Nolan Scott
Post by Nolan Scott »
Try Animation/Allow Frame Skipping.
Cheers
Nolan
undo
Post by undo »
thx alot!
jeff
Post by jeff »
If you have Quicktime on your computer, then choosing "export animation" from the File menu (shortcut Control+E) will render off a Quicktime movie for you that can then be played without leaving Moho. Be sure not to have the picture resolution in project settings set too high - use about 400 pixels width, for example, and you will find the rendering time is pretty fast for most sort of scenes.
Rai López
Post by Rai López »
...Don't forget F5 function key!!! :D
undo
Post by undo »
Ramón López wrote:...Don't forget F5 function key!!! :D
Ok, i´ll never forget, but wtf will it do?
Rai López
Post by Rai López »
If "wtf" means something like "what that feature/function" you only must have QT (QuickTime) installed and press it to know it... IT'S A GREAT "F"! ;)
gavi dvan
Post by gavi dvan »
Ramón López wrote:If "wtf" means something like "what that feature/function" you only must have QT (QuickTime) installed and press it to know it... IT'S A GREAT "F"! ;)
Hahaha :D Whenever I'm out in the street and something surprises me, you'll always hear me say "WHAT THE FUNCTION!?"
This is a block of text that can be added to posts you make.
There is a 255 character limit
jeff
Post by jeff »
Oops. Thanks for reminding us about F5 Ramón. I am ashamed to say I had forgotten about it.
Jeff
undo
Post by undo »
Well i´ve got QT installed and pressed F5 but no s*** happened ;)
could you be so kind to tell what should have happened?
Rasheed
Post by Rasheed »
Here are some screenshots of what happens when you press <f5>.
Image screenshot of Moho
Image just after pressing <f5> (preview is being prepared by Moho)
Image the preview is displayed in QT (here in the upper left corner)
And please, do not express your frustration with F or S bombs.
undo
Post by undo »
merci beacoup! :)
Rasheed wrote: And please, do not express your frustration with F or S bombs.
yeah, sorry,
guess thats because I´m listening to too much rocknroll-music ;)
