How do change the thickness of the lines
puzzles shum
Post by puzzles shum »
How do change the thickness of the lines when you are drawing
obtusity
Re: How do change the thickness of the lines
Post by obtusity »
If you are using a compatible pen/tablet, you can use pen pressure to vary line thickness when drawing with the Freehand tool.
If you are drawing with a mouse (or a tablet without pressure compatibility) you can change the line thickness at each node after you have drawn the lines, using the Line Width tool (will affect all selected nodes, or the nearest node if no nodes are selected).
puzzles shum
compatible pen/tablet is what i am using thanks for the fast reply and help
puzzles shum
puzzles shum wrote:compatible pen/tablet is what i am using thanks for the fast reply and help
my goal is drawing with pad and make it look like pencil drawing, what sending do i use
