smart bone target fix?
abd123
Post by abd123 »
for some when I have created smart bone and added a target to one of the character's bone it doesn't function outside frame 0. when I deleted the smart bone the target bone works again. is there is away to fix that problem and make them both work instead of deleting my smart bone?!
abd123
Re: smart bone target fix?
Post by abd123 »
I figure out that I have to use one keyframe and two smartbones for one bone if I want to allow target to work otherwise it will just not work! so for example:
if you want to work on bone "B1" you can create your first smartbone and point it at the left side do your fixing and create a new smartbone for the same bone "B1 2" and then point it at the right do your fixing.
if you tried to do too many keyframes the target wouldn't work!
I hope that helps anyone who have the same problem that I had
