How would you make it rain spiders?
willwillwill
Post by willwillwill »
I would like to have it start raining spiders and then when they hit the ground have them crawl all over the place. My question is how do you animate that many different elements at the same time. Is there a fast cheat sort of way to do that with them in a group?
This forum is really helpful thank you
Re: How would you make it rain spiders?
Ha ha! Interesting question... I've never done this, but I'd make a start with Particles. Hit New File, and go to the Scripts menu item on the top. Select Particle Effects, and then Rain. In the Layer palette you'll see six Vector Layers, p1 thru p6. These are raindrops, but you could change them to spiders (even wriggling spiders if you want to use animations instead of static images). That's the first half of your problem solved!
I'd next try to do something with Physics as the spiders hit the floor. You'll probably need to do about a dozen small animations of spiders running about in random directions and then fading out. You could switch to these animations as the spiders hit the floor. Hope this helps!
JanR90
Post by JanR90 »
Víctor Paredes wrote:Hi, here's a quick test for it:
https://dl.dropboxusercontent.com/u/544 ... icles.moho
haha xD víctor you're amazing!
YouTube Cartoon Jokes Channel: https://www.youtube.com/channel/UC2BQGB ... erPOIEXzAw
Youtube Personal Channel: https://www.youtube.com/channel/UCx_w74 ... 3jMryYMJeg
I want to thank everyone for liking, subscribing and support. You are awesome!
willwillwill
Holy crap that is so COOL! That is amazing thank you so much!
willwillwill
Ok I will try and do this and when I do I will try and show it to you. Thanks again
