PNG or PSD import
ghadiany
PNG or PSD import
Post by ghadiany »
Hi
I import a file with PSD format and rigged with Ctrl+Shift+F method.
I have two images, one image is in layer A and the other is in layer B.
and Have two Bones. Bone A and Bone B.
images are overlap in some parts.
The problem is appear when I manipulate the bones.
when I manipulate Bone A, image in layer A is moved or wrapped. also image in layer B is affected.
I have try to solved this problem by changing the bone strength and other way, but isn't useful.
This problem solved when I import my file as a PNG separated layers.
in this case, Layers not affected by the bones of the other layers.
I don't understand that the difference between PSD and PNG import.
