Problem
patricia3d
Problem
Post by patricia3d »
I had a destop with win 7 and installed Moho12 and it was working
now that system is crashed
and now I am trying to install on my laptop, after the installation when I run I am getting this problem
I have reinstalled the program, but the same problem.
zamasu
Re: Problem
Post by zamasu »
That's dll file missing from your computer here is link for that file :
https://www.dll-files.com/msvcr120.dll.html
Also any error with missing dll files you get just see which file is missing and find it on this site and put it in system32 folder "C:/windows/system32/" also just in any case copy it also in "C:/windows/sysWOW64"(if you have this folder I think only 64bit systems has it).
Hopefully this will help.
patricia3d
Re: Problem
Thanks for the help now the message is chnaged
zamasu
Re: Problem
Post by zamasu »
patricia3d wrote:Thanks your idea clicked
First of all try running it as administrator.(probably gonna be the same error but try it..), if it doesn't work,
I would recommend installing these again:
1.net framework (newest version)
2.Re-install Microsoft Visual C++
3.Re-install DirectX
also change moho that you are running in properties--> Compatibility--> run as administrator (it has to run as administrator)
if this doesn't help try this links below:
https://www.youtube.com/watch?v=UgwPlX5uNfs
http://www.tomshardware.co.uk/faq/id-19 ... 1500992100
https://appuals.com/fix-error-0xc00007b ... correctly/
I think you should be able to solve it, if nothing works try reinstalling Moho.Hope it helps!
