LUA console: what is it and is it a problem?
cabbage0896
Post by cabbage0896 »
Recently, after saving an item(any item character, prop, scene, etc.) to my library A small window pops up in the lower left hand corner of my screen. It's labeled "LUA CONSOLE" with the message: ( Mohodoc: layer by depth: out of range) , it doesn't seem to have any adverse affect on anything. My concern is I've never seen it before, what is it, and is it a problem? It's more annoying than anything, my question is how do I get rid of it? That's it for today.. Thanks.
C
Re: LUA console: what is it and is it a problem?
The Lua console just reports errors from the Moho tools. Unless you've added third-party tools or it pops up constantly, it's safe to just close it.
If it becomes a constant thing, even after restarting Moho, you might want to try finding the culprit tool.
But these are run-time errors, so you generally don't need to worry about them messing up files or anything.
there's another report of the same issue: http://lostmarble.com/forum/viewtopic.p ... 6&p=179005
that seemed to be solved by a reinstallation.
if it's still happening, and you're sure you don't have any 3rd party scripts installed, then it's a glitch in the main program.
Jkoseattle
Post by Jkoseattle »
I just installed 12.4 fresh and clean, and am experiencing the same issue when adding a layer to the library.
ADDITIONALLY: Moho often crashes completely right after this.
