Drag only works like right click
Jkoseattle
Post by Jkoseattle »
This happens all the time. I figure it's something I'm doing that causes it. Every so often, Moho will think that I'm right-dragging on the stage even when I'm using the left mouse. Usually this is when I am trying to move a layer somewhere. I'll select the layer, choose Transform Layer, and try to drag on the square around the layer to move it, but instead the whole stage moves exactly as if I were using the right mouse button to drag. I can't figure out how to get out of this state, and end up closing and restarting the program. I am definitely at frame 0, and it doesn't matter which layer I have selected. In fact, everything else in Moho seems to work correctly when in this state. It's just that I can't transform layers, and can only move the stage around. I also can't draw new layers. Think of it as Moho thinking I'm holding down the right mouse button regardless of which button I'm holding down. The actual right button works correctly, so in this state, no matter which button I hold down, it behaves the same. If I then open a new project, the same thing happens. Like I said, only closing and re-opening Moho completely resolves this problem.
