I thought I'd place my thoughts into a Camtasia project, and throw it up to YouTube. The Library panel of Moho Pro 12 doesn't extend fully, is all. A priority for the next upgrade, I suppose.
https://youtu.be/9sT0NIK_NJo
T'anks for any constructive feedback, … even from the peanut gallery crowd.
Library Panel Is Wonky
René Descartes drew the first ones.™ ©
Re: Library Panel Is Wonky
I had to render the setup to then realize I've set things up properly to Mask, after turning off GPU acceleration in the Display Quality panel. Wow.
This tutorial guy didn't have to render to realize the Mask effect: https://youtu.be/Tp8j1ADhdKw …
Onward …!
https://www.dropbox.com/s/dqkq6n7xclo3f01/m1.png?dl=0
I'll learn the basics of animation with Moho Pro 12 software. I'll move on to Toon Boom when the bucks roll in
Had I learned Flash when it first came out I'd run to the familiar Adobe Animate CC. If anyone asks I'll have to recommend Toon Boom, … if the resources are there to do so. Quality is a key. Learning curve is steep too, but fewer bugs. Moho Pro could use a major overhaul.
#idiosyncratics
#sad
#idiosyncratics
#sad
