How do I achieve the anime style lighting effects?
ezekielloves
Post by ezekielloves »
I really love anime style and am grateful Moho is newbie friendly for 2D animation :D . But, I'm stuck.
Take a look below.
Creator Mikeinel achieved this via After Effects. But, how do I achieve the same kind of lighting effects in Moho Pro?
Re: How do I achieve the anime style lighting effects?
Well, this is easy enough to reverse-engineer. Use a GIF screen recorder (I used Screen2Gif), save as a PNG sequence to a nominated directory, and examine each frame to see how to replicate that effect.
chucky
Post by chucky »
It is best to use a post effects but it is possible in Moho, the render takes a few seconds longer
That came up about 10 years ago, here's about three pages on it.
viewtopic.php?f=5&t=12239&start=15
Since then, Moho has added auto shading which helps the dark bleed.
Also references help with the multilayered approach.
Here's an example with an old piece I dug up from the crypt and applied some techniques that I'll share the recipe for in the next post.
chucky
Post by chucky »
to get the bloom on the character = 3 copies/references
Character 1 leave clean, it's the refrenced master. It's at the bottom of the stack.
Character 2 ( referenced) This is the dark bleed , Set to Luminosity blend mode.
General-Auto shading radius 2
Shadows- Layer Shading ON Offset 40 Blur 40 Shading Colour - Black Direction -down
:idea: Put these 2 characters in a group - masking- hide all- this elimanates the white edge issue.
Character 3 ( referenced) above the other two , outside the masking group. This is the bright bloom. Set to Screen Blend mode.
Blur radius 20, Opacity 20, Auto shading 6
Layer Shading ON , Offset 7, Blur 15, contraction 20 SHading Colour Balck ,angle down.
Bake for 40 minutes on a high Fan Forced Oven.
Serve with a robust red.
chucky
Post by chucky »
If you were talking about the bright rim light then that's a whole different matter and I'll let someone else explain. :mrgreen:
Try this for a rimlight. Double-click on your vector layer, choose the Shadows tab, then click Layer Shadows. Enter the settings here:
Should give you something like:
You can mess around with the settings to get different effects...
(You'll need to render an image [CTRL-R] to see it)
chucky
Post by chucky »
Or this ,
or just manually add the white shapes to another reference
That's a beautiful style. I wish recent content in german TV would meet this standard.
SuperSGL
Post by SuperSGL »
Still learning new things in MOHO I wondered what the expansion was for but never really tested it. Nice effect I was just using the fill Halo before thanks for the tip. But of course...it's in the manual :oops: :roll:
Norman McLaren
My Animations
