Insert text on Linux (Ubuntu) doesn't work.
racoon97
Post by racoon97 »
I have a little problem to insert text : no font is available like this topic :
http://www.lostmarble.com/forum/viewtop ... light=text
My moho run on Linux Ubuntu 5.10. How to do to Moho could found the fonts ?
jorgy
Post by jorgy »
I think you will need to edit line 31 of the "moho" script itself. On my Fedora Core 4 box, I changed it to look like:
export MOHO_FONTS=/usr/X11R6/lib/X11/fonts/Type1
The other place that fonts might be is /usr/share/fonts/default/Type1 (you may want to google on this). Finally, you could copy over your ttf files to another directory and put that directory name into this directory. I usually just copy my ttf files into /usr/X11R6/lib/X11/fonts/Type1.
Hope this helps,
jorgy
racoon97
Post by racoon97 »
Thanks a lot !
It's works now :D
