Using switch layers
x-vishon
Using switch layers
Post by x-vishon »
Just wondering how to animate switch layers with out any scripts.... Just change frames and click on the one you want to show that frame?
Rai López
Post by Rai López »
Of course, that is the usuall way to work with Switch Layers if you don't hava a *.dat file or you want make changes manualy... Well, as you can see in the manual ;), you have two options, go to the desired frame and click with Righ Mouse Button over the Switch layer in Layers Window to select the name of the desired subLayer that you want mostrate in the PopUp menu; another way is selecting the Switch Layer Tool (the penultimate tool in Tools Window Layer Section) and make the changes over Sensitive Tool Menu, just abobe your Editing Window, CIAO!
