Invert Brush Orientation Option (It'd Be Nice)
Rai López
Post by Rai López »
HELLO! I usually work with not centered brushes, and sometimes the orientation of the brush can be a problem that could have (I think) an easy solution with an option near "Aling brush with curve" setting to can invert the orientation of the brush along the curve... Actually seems that it is decided when you draw your line and there is no way then to change it without have to delete and redraw your lines... Well, THANKS! :)
Rai López
Post by Rai López »
EY! I've encountred a way! :D It was easy (and useful to me now :)) Well, the case is that if you join that curve you want change orientation with other oriented in diferent way you can conmute between the two ways! Depending which you join with which! It's important to me so --> :D ...CIAO!
