Render Changing Layer Order?
x-vishon
Post by x-vishon »
So I have an issue with a animated head turn. When the turn is done in the work space its fine but when the head is turned and the layer with the hair that needs to be behind the head moves back when I render the layer still frame or video the layer order pops it back to the front. I will attach the .moho file to the post.
I have no sweet clue how this happened or how to fix it but why is render popping the layer up?
https://drive.google.com/file/d/1G0YmfV ... sp=sharing
~ David McInnis
x-vishon
Re: Render Changing Layer Order?
Post by x-vishon »
So I tracked down the issue sort of. So the layer stops reordering it self if I turn motion blur off. If I turn it on in the Bone layer or the Folder or anywhere above the head then it starts doing the thing where it reorders itself during render. Any ideas as to why and what the fix would be.
~ David McInnis
