i exist in frame zero,nicely boned up and moving smoothly.
however when i move the time line to beyond fame 1 my character simply disapears.
i know this must be something very simple that ive overlooked.
please can someone advise. ive spent weeeks importing characters from ai. im going crazy!
thanks in advance
( ps.. i had several bone manipulation practice sesssions and i never encountered this before. whats going on?? )
help? im invisible
- stephklein
Check through your menus at the top of the screen and look for an option called "Clear Animation From Layer" or something like that. This should restore everything on the current layer to how it looks in frame zero.
If there's nothing at all animated in your project so far you could also use the option "Clear Animation From Document" to reset the whole thing.
Hope this helps
Hope this helps
This is a block of text that can be added to posts you make.
There is a 255 character limit
Check your depth sorting. Each layer needs to be "0" or negative, otherwise it will be behind the camera once you leave frame 0. Also, don't mix depths in the same layer folder - this will confuse MOHO and cause objects to disappear. I've made all these mistakes.
Can a no-talent hack make cartoons with just clip art and a Mac? You bet!
