Scale key frame option when changing FPS
There is already a scale key frame command.
If this could be linked to the FPS in the project settings that would be great.
Changing FPS in the project settings would have an option to scale the key frames maintaining the same time.
For instance... 600 frames at 24 fps changed to 30 fps would give you 750 frames. Uniformly scaling the frames.
You could do this by hand but it would be nice to have it built in.
p.s. Papagayo needs this as well.
-Vern
