Moho 13.5.1 shape copy-paste bug
Gosha
Post by Gosha »
Hello!
In Moho 13.5.1 on Windows 10 I noticed a problem that sometimes when I copy some shape from layer to new layer, it can be distorted.
Not always. but sometimes.
I think this is due to the fact that for some reason the parameters of curvature change and the figure is distorted.
There is no such bug in version 13.
Re: Moho 13.5.1 shape copy-paste bug
Sometimes? When?
When you're pasting into a transformed layer or one with bone influence?
Gosha
Post by Gosha »
I couldn't tell why this is happening. I just worked and one figure was also distorted. See screenshot.
The left is what it should be, the right is how it was distorted after copying.
This is a normal layer, no bones and no transformed.
I did exactly the same operation in version 13 and there was no such problem.
Can you share a file with just the problem shape/s?
Gosha
Post by Gosha »
Here it is
Try to select this shape and then copy to a new layer. When I just make duplicate everything works. But when I copy, it breaks.
https://file.io/3DDdeY8NBdlL
Gosha
Post by Gosha »
I found the problem.
When I uncheck the layer properties "legacy curves" everything is ok.
And when the parameter is turned on, distortion occurs
Glad you got it sorted. Yeah, legacy curves are not compatible with being pasted into a non-legacy curve layer. The option really only exists for backwards compatibility with older files. I wouldn't recommend using it, if you can avoid it.
Gosha
Post by Gosha »
Thank you for your assistance!
