get missed images
davoodice2
get missed images
Post by davoodice2 »
hi.
how to detect image layer's source is missed or not!
is there some thing like:
ImageLayer:SourceIsMissed() ? :D :D
Re: get missed images
Check to see if ImageLayer:SourceImage() is a valid path, using io.open. Be sure to close the file, io.close(path), if it's valid.
SimplSam
Post by SimplSam »
An alternative file test in Lua is to use os.rename, where you try to rename a file to itself. This will do nothing to the file - but will return true if the file is renamable, and nil* if the file is missing etc.
if os.rename(myfile, myfile) then
  DoSomething
end
*Note: os.rename will also return the reason if the rename fails.
result, reason = os.rename(myfile, myfile)
io.open can also give error messages, but os.rename is more efficient. Good one, Sam.
davoodice2
thanks and excuse me for more questions.
why when we import psd as layers, scale is always equal to 1. but when we replace it, it's actual size in viewport change?(when it is into scaled group).
I wrote a script to fix that. but with change scale of layer. and I sure it is bad. can I replace psd with code without changing scale and preserve layer size?
and I noticed when I replace a layer that is into a scaled group with moho itself, when I use undo right after replacement, size of image will fixed.
Lukas has dealt with that more than I. Maybe he'll chime in.
Lukas
Post by Lukas »
Yeah, this is troublesome and I wish image Height and Width would not be related to the project Size at all but here we are. It would be nice to be able to set image Height and Width by script, but we can't.
I currently also adjust the scale of image layers, I'm not happy about messing up the files, but there's currently no other way:
	-- * Check old size:
	local oldHeight = imageLayer:Height()
	imageLayer:SetSourceImage(imagePath)
	-- * Compare to new size:
	local newHeight = imageLayer:Height()
	-- * Check if difference is significant:
	local heightDifference = math.abs (oldHeight - newHeight)
	if heightDifference < 0.1 then
		heightDifference = 0
	end
	-- * Change size on frame 0 and timeline:
	if heightDifference ~= 0 then --newHeight ~= oldHeight then
		self.changedScale = true
		local heightChange = oldHeight / newHeight
		local scaleChannel = imageLayer.fScale
		local oldScale = scaleChannel:GetValue(0)
		local newScale = oldScale * heightChange
		-- * Main timeline scale channel for this image layer:
		local endKey = scaleChannel:Duration()
		local thisKey = 0
		local keyCount = scaleChannel:CountKeys()
		local keysFound = 0
		local frameNum = endKey
		while keysFound < keyCount do
			thisKey = scaleChannel:GetClosestKeyID(frameNum)
			keyFrameNum = scaleChannel:GetKeyWhen(thisKey)
			keysFound = 1 + keysFound
			-- * Scale it:
			local oldScale = scaleChannel:GetValue(keyFrameNum)
			scaleChannel:SetValue(keyFrameNum, newScale)
			frameNum = keyFrameNum - 1
		end
		-- * Do all action scale channels for this image layer too:
		for i = 0, scaleChannel:CountActions()-1 do
			local actionChannel = moho:ChannelAsAnimVec3(scaleChannel:Action(i))
			local endKey = actionChannel:Duration()
			local thisKey = 0
			local keyCount = actionChannel:CountKeys()-1 -- * -1 because we don't want to modify frame 0 in actions!
			local keysFound = 0
				thisKey = actionChannel:GetClosestKeyID(frameNum)
				keyFrameNum = actionChannel:GetKeyWhen(thisKey)
				-- * Scale it:
				local oldScale = actionChannel:GetValue(keyFrameNum)
				actionChannel:SetValue(keyFrameNum, newScale)
			end
		end
	end
