Masking no longer works after export
Sandra HH
Post by Sandra HH »
Good evening,
I am slowly starting to feel comfortable in Moho. Thanks also for all the great advice in this forum.
Currently, however, I have a strange problem with the masking. It is displayed correctly in the preview and also when rendering the preview. Only when exporting the animation does the masking no longer work.
I'm a bit helpless at the moment as to where else to look. I would be very grateful for any tips. I captured the problem in a screen capture:
Many thanks and best regards Sandra
Sandra HH
Re: Masking no longer works after export
Post by Sandra HH »
Hey,
I have solved the problem, but unfortunately can not explain what it was. After I removed the outline from the mask layer (lips) the masking worked. Then I chose other brushes for the line and this also worked. In the end I set the original used brush again and crazy enough the mask now works after the export.
Maybe this procedure will help someone if this phenomenon actually shows up again. :D
Best regards
Sandra
