Moho2AE script
Gherasimov Vasile
Moho2AE script
Post by Gherasimov Vasile »
Hello friends, I have a request for those who know coding. Please help me to adapt the given script to work with PSD files as well, if possible, so that when you open in AE, it also receives information about the location of the files, and then opens them in composition
https://prnt.sc/r-s10uVgUttx
-- Provide Moho with the name of this script object
ScriptName = "CM_Moho2AE"
CM_Moho2AE = {}
function CM_Moho2AE:Name()
	return 'Export to After Effects jsx'
end
function CM_Moho2AE:Version()
	return '1.0'
end
function CM_Moho2AE:UILabel()
end
function CM_Moho2AE:Creator()
	return 'Community test'
end
function CM_Moho2AE:Description()
	return 'Create .jsx script which been called from AE imports all the bitmap images of moho bitmap layers and (optionaly) rendered sequences of moho vector layers, placing it into new composition in correct order and position (optionaly with layer animation too)'
end
-- Is Relevant / Is Enabled
function CM_Moho2AE:IsRelevant(moho)
	return true
end
function CM_Moho2AE:IsEnabled(moho)
	return true
end
-- CM_Moho2AEDialog
local CM_Moho2AEDialog = {}
function CM_Moho2AEDialog:new()
	local d = LM.GUI.SimpleDialog('Export to After Effects jsx', CM_Moho2AEDialog)
	local l = d:GetLayout()
	return d
end
-- The guts of this script
-- map moho blending mode constants to AE blending mode constant names
CM_Moho2AE.blendingModesMap = {
	[MOHO.BM_ADD] = "BlendingMode.ADD",
	[MOHO.BM_COLOR] = "BlendingMode.COLOR",
	[MOHO.BM_DIFFERENCE] = "BlendingMode.DIFFERENCE",
	[MOHO.BM_HUE] = "BlendingMode.HUE",
	[MOHO.BM_LUMINOSITY] = "BlendingMode.LUMINOSITY",
	[MOHO.BM_MULTIPLY] = "BlendingMode.MULTIPLY",
	[MOHO.BM_OVERLAY] = "BlendingMode.OVERLAY",
	[MOHO.BM_SATURATION] = "BlendingMode.SATURATION",
	[MOHO.BM_SCREEN] = "BlendingMode.SCREEN"
function CM_Moho2AE:ResourcePath()
   local str = debug.getinfo(2, "S").source:sub(2)
   local _, slashPos = string.find(string.lower(str), "scripts")
   local slash = string.sub(str, slashPos+1, slashPos+1)
   local pattern = "(.*\\)[mM]enu\\.*"
   if slash == "/" then pattern = "(.*/)[mM]enu/.*" end
   return (str:match(pattern) .. "ScriptResources".. slash .. "moho2ae" .. slash), slash
end
function CM_Moho2AE:Run(moho)
	--dialog call to uncomment later
	local dlog = CM_Moho2AEDialog:new(moho)
	if (dlog:DoModal() == LM.GUI.MSG_CANCEL) then
		return
	end
	moho.document:SetDirty()
	moho.document:PrepUndo(nil)
	-- read some common functions for jsx
	local jsxCommonFunctionsPath = self.ResourcePath().."common.jsx"
	local file = io.open(jsxCommonFunctionsPath, "r")
    if not file then
		return LM.GUI.Alert(LM.GUI.ALERT_WARNING, "No " .. jsxCommonFunctionsPath)
	end
    local content = file:read "*a" -- *a or *all reads the whole file
    io.close(file)
	-- ask user for output file
	local path = LM.GUI.SaveFile("Select JSX File")
	if (path == "") then
		return
	end
	if string.sub(path, -4) ~= ".jsx" then path = path..".jsx" end
	local f = io.open(path, "w")
	if (f == nil) then
		return
	end
	io.output(f)
	-- write some common functions for jsx
	io.write(content)
	-- write creation of main comp with this comp size and duration
	local name = string.sub(moho.document:Name(), 1, -6)
	self.w = moho.document:Width()
	self.h = moho.document:Height()
	self.fps = moho.document:Fps()
	self.dur = moho.document:EndFrame() - moho.document:StartFrame() + 1
	self.seconds = self.dur/self.fps
	io.write(string.format('var mainComp = app.project.items.addComp("%s", %s, %s, 1, %s, %s);\n', name, self.w, self.h, self.seconds, self.fps))
	io.write(string.format('var mainFolder = app.project.items.addFolder("%s");\n', name))
	io.write('mainComp.parentFolder = mainFolder;\n')
	self.globalVarNameIndex = 0
	io.write('var cameraNull = mainComp.layers.addNull();\ncameraNull.name = "camera";\n')
	io.write('var persNull = mainComp.layers.addNull();\npersNull.name = "pers";\n')
	self:BakeCamera(moho)
	for i = 0, moho.document:CountLayers() - 1 do
		local nextLayer = moho.document:Layer(i)
		local nextCompLayerName = self:ProcessAnyLayer(moho, nextLayer, 'mainComp')
	end
	io.close(f)
end
function CM_Moho2AE:BakeCamera(moho)
	--TODO: set animation for persNull and cameraNull layers, baking camera animation from Moho (see ae_export_2d_camera.lua for baking formulas)
end
function CM_Moho2AE:ProcessAnyLayer(moho, layer, parentCompVarName, folderName)
	if not folderName then folderName = "mainFolder" end
	local nextIndex = self.globalVarNameIndex + 1
	local name = 'layer' .. nextIndex
	self.globalVarNameIndex = self.globalVarNameIndex + 1
	local layerType = layer:LayerType()
	local newFootageItemVarName = nil
	if layerType == MOHO.LT_GROUP then
		--create folder for footage
		local newFolderName = 'folder' .. nextIndex
		io.write(string.format('var %s = %s.items.addFolder("%s");\n', newFolderName, folderName, layer:Name()))
		newFootageItemVarName = self:CreateGroupFootage(moho, layer)
		io.write(string.format('%s.parentFolder = %s;\n', newFootageItemVarName, folderName))
		for i=0, moho:LayerAsGroup(layer):CountLayers() - 1 do
			local nextLayer = moho:LayerAsGroup(layer):Layer(i)
			self:ProcessAnyLayer(moho, nextLayer, newFootageItemVarName, newFolderName)
		end
		io.write(string.format('if (%s.items.length == 0) %s.remove();\n', newFolderName, newFolderName))
	elseif layerType == MOHO.LT_IMAGE then
		newFootageItemVarName = self:CreateBitmapFootage(moho, layer)
	elseif layerType == MOHO.LT_BONE then
		newFootageItemVarName = self:CreateSequenceFootage(moho, layer)
	end
	if not newFootageItemVarName then return nil end
	-- place resulting footage (composition, image or sequence) into parent composition
	if layerType == MOHO.LT_GROUP or layerType == MOHO.LT_IMAGE then
		io.write(string.format('var %s = %s.layers.add(%s);\n', name, parentCompVarName, newFootageItemVarName))
		self:ApplyLayerTransform(moho, layer, name)
		if not layer:IsImmuneToCamera() then
			io.write(string.format('%s.parent = cameraNull;\n', name))
		end
	elseif layerType == MOHO.LT_BONE and #newFootageItemVarName > 0 then
		for k, v in pairs(newFootageItemVarName) do
			io.write(string.format('var %s = %s.layers.add(%s);\n', name..v, parentCompVarName, v))
			io.write(string.format('%s.parent = persNull;\n'), name..v)
		end
	end
	self:ApplyLayerBlending(moho, layer, name)
		-- set collapse transformations on
		io.write(string.format('%s.collapseTransformation = true;\n', name))
	end
	return name
end
function CM_Moho2AE:CreateGroupFootage(moho, layer)
	local name = 'comp' .. nextIndex
	-- create new composition with same parameters as main one
	io.write(string.format('var %s = app.project.items.addComp("%s", %s, %s, 1, %s, %s);\n', name, layer:Name(), self.w, self.h, self.seconds, self.fps))
	return name
end
function CM_Moho2AE:CreateBitmapFootage(moho, layer)
	local name = 'img' .. nextIndex
	-- import bitmap
	local imageLayer = moho:LayerAsImage(layer)
	local path = string.gsub(imageLayer:SourceImage(), "\\", "\\\\")
	local args = string.format('"%s"', path)
	if imageLayer:IsPSDImage() then
		args = args .. string.format(', %s', imageLayer:PSDLayerOrderID() + 1)
	end
	-- call jsx function with these args (to import single bitmap or PSD file or use PSD layer allways imported for another layer of same moho project
	io.write(string.format('var %s = FindOrImport(%s);\n', name, args));
	return name
end
function CM_Moho2AE:CreateSequenceFootage(moho, layer)
	local characters = {}
	--TODO: find all the layercomps which include this layer
	--TODO: compute path to rendered images (ask user in first dialog and save to script preferences)
	--TODO: import sequence (if exists, or offline dummy if does not) to AE via jsx
	-- return array of new layers' names
	return characters
end
function CM_Moho2AE:ApplyLayerTransform(moho, layer, layerVarName)
	-- set ae anchor and position to moho values
	local aeAnchor = layer:Origin()
	aeAnchor.x = aeAnchor.x * self.h/2
	aeAnchor.y = -aeAnchor.y * self.h/2
	local aePos = layer.fTranslation:GetValue(1)
	aePos.x = aePos.x * self.h/2 + self.w/2 + aeAnchor.x
	aePos.y = - aePos.y * self.h/2 + self.h/2 + aeAnchor.y
	if layer:LayerType() == MOHO.LT_GROUP then
		aeAnchor.x = aeAnchor.x + self.w/2
		aeAnchor.y = aeAnchor.y + self.h/2
	elseif layer:LayerType() == MOHO.LT_IMAGE then
		aeAnchor.x = aeAnchor.x + imageLayer:PixelWidth()/2
		aeAnchor.y = aeAnchor.y + imageLayer:PixelHeight()/2
	end
	io.write(string.format('%s.position.setValue([%s, %s]);\n', layerVarName, aePos.x, aePos.y))
	io.write(string.format('%s.property("Anchor Point").setValue([%s, %s]);\n', layerVarName, aeAnchor.x, aeAnchor.y))
	-- set ae rotation to moho values
	local aeAngle = -180 * layer.fRotationZ:GetValue(1)/math.pi
	io.write(string.format('%s.rotation.setValue(%s);\n', layerVarName, aeAngle))
	-- set ae scale to moho scale and flip values
	local aeScale = layer.fScale:GetValue(1) * 100
	if layer.fFlipH:GetValue(1) then aeScale.x = -aeScale.x end
	if layer.fFlipV:GetValue(1) then aeScale.y = -aeScale.y end
	io.write(string.format('%s.scale.setValue([%s, %s, %s]);\n', layerVarName, aeScale.x, aeScale.y, aeScale.z))
end
function CM_Moho2AE:ApplyLayerBlending(moho, layer, layerVarName)
	--TODO: set blending mode, transparency and visibility from moho layer to AE
end
jayfaker
Re: Moho2AE script
Post by jayfaker »
Can you tell us what the script does? I'm very interested in this one.
Gherasimov Vasile
Re: Moho2AE script
jayfaker wrote: Thu Apr 06, 2023 9:48 pm
create a json file with the data from the Moho scene, and you can open it in After Effects
jayfaker
Re: Moho2AE script
Post by jayfaker »
Can you tell me where to find common.jsx?
Okay, I get it, the script isn't finished. I wanted to know if the script is actually creating shape layers in AE from the vector shapes in Moho. That would be super useful to me because I have to use After Effects to create lottie files - essentially animated vector files for website use. I would love to be able to animate in moho, and send the vector information to after effects where I could then create the lottie file. I know moho can export .svg sequences, but it's not quite the same thing. Anyway, let me know.
Thanks!
Jim
