Changing Line Color
Fonce Falooda
Changing Line Color
Post by Fonce Falooda »
Hey! Trying out the Frame by Frame mode. When I've made a big sketchy mess on one frame with 100 individual little lines, how can I change their color all at once?
I select all the points, but changing the Stroke color does nothing. I try to Select All with the "Select Shape", but it won't let me. I can select ONE LINE with the Select Shape tool and change the color, but there are a whole bunch of them.
Does it has something to do with Styles? I've been drawing with the Gouache preset.
How do I change the color of all these lines? Thanks! :)
Fonce Falooda
Re: Changing Line Color
Holy crap! I just did it! There's a "Select All" BUTTON at the top of the screen, when you're in Select Shape tool, that WILL Select All!
The Shortcut didn't work, the drop-down menu item didn't work, but the big button did! Chaos.
Anyway, convert this thread into a Bug Report about those first two "Select All"s, please. :)
SimplSam
Post by SimplSam »
Select All - Menu and Shortcut - selects all Points, on the Shape and Layer Transform tools. It is a bit weird, but it has its uses when Cutting, Copying & Pasting points.
Fonce Falooda
But it doesn't mention "points" anywhere, it just says "Edit > Select All", and I had the Select Shape tool active.
"Select None" works like it should, though that apparently is just a coincidence. ;)
Learning now about Styles. Think that's the way I SHOULD have been doing it, but I just found a nice brush and started drawing, and immediately hit a strangeness. Bet it won't be the last one. :p
