How to use Tourbox to rotate bones?
ilvmgct
Post by ilvmgct »
Scungeeoh
Re: How to use Tourbox to rotate bones?
Post by Scungeeoh »
Howdy,
Do you mean to use the Manipulate Bones Tool and instead use something like the Knob on the TourBox to actually move the bone??
There is sort of a way but it is finicky. Set the Manipulate Bones Tool to a button like say the C2 button on the Tourbox. Then when you set the Knob, go to the fn Built-in tab and go to the bottom of the menu. I am on a Mac but at the bottom of the list I am able to choose Mouse Drag Simulation. There is a little cog and when you click on it you can choose Horizontal Dragging and Speed and Acceleration.
When you are back in Moho, click on C2 or whichever button you assigned the Manipulate Bones Tool, and then when you move over a bone on a character, etc, you can use the Knob to rotate/manipulate the bone. It is fiddly as I say, and when you move over another bone you can use the Knob to manipulate that bone. You don't have to actually select each bone but hover over it and the Knob will let you move it. It may not be worth it for some people, and I don't even know what I think of it yet to be honest.
If I have the time maybe I can post a short video of it in a couple days.
ilvmgct
Post by ilvmgct »
Thank you for your suggestion. I tried using the touchpad to simulate mouse x-axis dragging to experience it, but it was not flexible and almost unusable;
In Moho, bone rotation is achieved through the linkage of x and y coordinates using a real mouse;
In my expectation, when rotating the tourbox knob without acceleration, if the knob rotates 360 degrees, Moho's bones will correspondingly rotate 360 degrees This experience of rotation should be smooth, but simulating mouse drag and drop is almost unusable;
