I've got 2 movies and I want to merge them. The first movie is 400 frames, the secend 300 frames. The second movie has to be placed after the first: in the new merged movie frame 1-400 come from movie1, frame 401-700 come from movie 2. Is there a trick for doing this in moho or should I use my video editor to do this?
My first choice would always be to use a Video-Editor.
In Moho you could import your movies via the Image-import in the Layers,
(or just drag them into your viewport).
and animate the Opacity in the Layer-Settings, fading one movie out and the other one in.
Thanx for the answer, I guess I made a mistake in explaining my question: I don't want to merge two movies that are already rendered out to a mov or avi file. I want to merge two Moho files into one moho file.
Go to File/Import/Moho Object/choose your Moho file/
in the Insert Object window choose the Layer and click OK.
(if you have organized your file in One Group-Layer only this
Layer will appear in the Insert Object window).
