Animating particles on a path
JCook
Post by JCook »
Is there a way to make particles move along a path? I need to show an ocean current, and show which way it flows, and I thought particles might do the trick, but I can't get them follow the curve. I've downloaded the macton scripts and I can get a shape to follow the curve, but not particles. I also have to animate the curve itself and make it change shape, and the particles need to still follow the curve as it's changing shape as well. A complicated problem.
Anyone have any ideas about how to do this, with particles or any other ingenious method? I'm open to anything that works. I don't even need to use the particles, it was just an idea I had. Basically, I need to animate this curve, while showing the direction that it would be flowing in.
thanks,
Jack
bupaje
Post by bupaje »
Check out this thread and see if it helps.
http://www.lostmarble.com/forum/viewtopic.php?t=1956
Lost Marble had also posted an example somewhere of particles showing blood flow in a human heart, or maybe this was in the official examples with the product - not home now so can't check.
JCook
Post by JCook »
Thanks, bupaje, I'll check out that tutorial. It looks like it may have some possibilities. I don't know if it will help with the part where i have to change the shape of the path though, but I'll try it.
Jack
bupaje
Post by bupaje »
Ah, missed that part about moving the curve. I'm still a 'Moho-tinkerer' so not sure. Not exactly sure what you are doing but if you can't animate the curve and have particles follow it as it animated maybe you can generate particles on a layer and use an animated mask to expose the movement you want?
JCook
Post by JCook »
I gave the tutorial a try and after a few problems was able to make a waterfall like that one. So now I'm going to try it using a more complex path, and a moving mask. this may prove to be pretty tricky. I'll let you know how it comes out (might be a few days)
Jack
