1. are there quickkeys to jump forward or backwards between different keyframes or actions in the timeline?
2. is there a way to isolate a section of the timeline? Like the "work area" in after effects. If you arent familar with AE what I am meaning is say that I am working in a timeline that is 30 seconds but I am tweaking a section of keyframes in the first 3 seconds of the animation. Is there a way to isolate that first 3 secs so what I preview the animation it will loop at the end of that three secs and not go for the full 30 secs?
Thanks
Questions about timeline
DarthFurby
2. Holding the "Alt" key and left or right clicking will set the beginning and end of the animation. Holding the "Ctrl" key and left or right clicking will sett the beginning and the end of what is previewed inside moho. If you want to set the range of the final animation, use "Alt", if you want a specific range to be played when you press the play button, use "Ctrl".
