What am i doing wrong?
blackspittle
Post by blackspittle »
Here is a link to the moho file im working on, anytime i add bones it doesn't move smoothly! please look at it and try to add bones to it and tell me what im obviously doing wrong! I'd really appreciate it!
http://www4.upload2.net/download/z66CAg ... dibia.moho
49kb
Thanks!
" but what good is a muffin if your not alive to eat it" - agent 'smink'-----(lucky bob's time machine)
I looked at the file...
Can you be more specific about your trouble?
First off you have more points than you really need... but that isn't so bad.
I would reccomend you rotate the forearms to be straight in line with the biceps... doesn't have to be all the way straight... but you want to be able to use a bone for the forearm area and not have the bone in the bicep competing for control of the points.
Are you using Flexible Binding on the bone layer or Region Binding? They behave very differently.
When you say "it doesn't move smoothly" do you mean at the joints of the bones? That would be your "too many points" problem... but you can spread out the bone strength to smooth that out.
There was no bone layer in the file you provided so no info on where the trouble might be.
You should do ALL the tutorials. Those are a HUGE help. Focus on the ones that use bones.
I could add the bones to your file as requested... but then you don't learn anything. ;)
-Vern
blackspittle
Whenever i add bones to all parts, and i try to manipulate it, eg the lower arm bone the head moves! and when i said add bones i mean you should try it and try to manipulate it and see how it behaves... thanks man you rule
Sounds like a parenting issue.
When adding bones you must add them or parent them in the proper order.
I start with the hips and keep adding bones to the head (hips, torso, neck, head).
I select the torso and add the arm bones (bicep, forearm, hand). Remember you have to reselect the torso bone to add the other side arm bones.
Leg bones should be parented to the hips.
... the foot bone's connected to the... shin bone... the shine bone's connected to the... thigh bone... etc etc...
I sing that song as I work. ;)
If you are using flexible binding on the bones layer... it could be that... that is causing shapes to move where they shouldn't.
Flexible binding means that ALL the bones influence EVERYTHING.
I find region binding to be better... more control. In your file the head was in a group layer... so... the group would be inside a bone group and you would "bind" that head group to the head bone.
Bone binding and bone parenting is explained in the help files and the tutorials.
blackspittle
The character i drew doesn't have legs or hips... just torso arms and head...
blackspittle wrote:The character i drew doesn't have legs or hips... just torso arms and head...
Yes I noticed that... I figured it might be a work in progress. ;)
blackspittle
Sorry for the wrong impression, but it's not, thats how i intend the character to be...
blackspittle
This is another one, i added the bone, please try to manipulate the lower left arm bone and see what happens to the head! then you could tell me what i'm doing wrong. I'm getting real fustrated with this! :cry:
http://www4.upload2.net/download/tWQJ1D ... qddie.moho
The link doesn't go to the right place. It looks like some kind of AVI file and it won't download.
dekka
Post by dekka »
hi black spittle,
i had a look, what it looks like is that your head folder is actually bound the arm so select the arm bones select the head group layer and release the layer then select the head bone select the head layer and lbind the layer to the bone, does that make sense, i also think that you have some small problems with the torso, you have to be careful that you only select the appropriate points when you bind points to a bone.
hope that helps
blackspittle
No! i don't get it , but i get my problem now! :( It's the group layer! How do I add parts of a group layer (eg eyes mouth hair) into a bone layer the dragged the whole roup layer into the bone layer and it glowed red and seemingly 'entered' but it's parts eg eyes mouth etc still have that little 'dot' in front of them... and thanks guys for replying me, thanks for caring...
Thanks
blackspittle
You are using FLEXIBLE BINDING on the bone layer.
The head GROUP LAYER moves because with FLEXIBLE BINDING set on the bone layer properties... EVERY BONE EFFECTS EVERYTHING.
Set the bone layer to REGION BINDING.
Did you read the help file yet for bone layers? Have you done the bone tutorials yet? I can help out but you should at least do that first.
blackspittle
I switched it to regional binding on the bone layer still it doesn't work! i've been through the bone tutorial, at least i have an idea of it, still it doesn't work right! :(
CowsCanFly
Post by CowsCanFly »
try making it without the head group...
