switch layer moving with the head
laeyzer
Post by laeyzer »
I'm pretty new to moho, owned it for a while but we are starting to use it now.
the question is: I made a head and just used one of the existing mouth shape layers that is switched for testing.
I put a couple bones in the head so i can animate the jaw. now when i move the head bone, everything moves except the switch layer. how do i constrain the switch layer to move with the rest of the head???
Or can you?
i snooped around a bit on the forum but didnt find anything. if there was a post for this just give a link.
hope someone can help!
(the head is moved with the bone)
7feet
Post by 7feet »
Use the "Bind Layer"tool (bottom left button in the Bone section of the tool window. Select the layer (the switch layer in this case, click on the tool, and then click on the bone you want the layer attached to.
laeyzer
Post by laeyzer »
7feet wrote:Use the "Bind Layer"tool (bottom left button in the Bone section of the tool window. Select the layer (the switch layer in this case, click on the tool, and then click on the bone you want the layer attached to.
Wow, simple as that. thanx.
im sure i will have more questions.
