->File -. Render
Ashe Raven
->File -. Render
Post by Ashe Raven »
Hi I was hoping someone could help me out here
I am following the tutorials but when it comes to telling me to use the Render option in the File menu, I find there is no render option in this menu.
Is this becasue I am using the bog standard version and not the pro version or am I missing something? Thanks to any help you can offer me :)
Patmals
Post by Patmals »
Hi Ashe,
The Render option SHOULD appear under the Preview option
eg.
File
New
Open
Close
Save
Save As...
Project Settings...
Inport
Preview
Render
Export Animation...
Batch Export
Quit
Patmals
Post by Patmals »
Im using Pro so i am not sure...
Lost Marble
Post by Lost Marble »
Hmm, yes, this is because the Render command is not available in the standard version. You can get the same result using the File->Export Animation command. The difference is that Render shows you just the current frame in a window, while Export Animation exports the whole animation (or you can specify a subset of frames) to a movie file.
Sorry - apparently we missed those references to Render in the manual.
Ashe Raven
Thanks for the assist. The documentation is pretty vague as to what version can do what, for example the particle system can only be accessed through the pro-versio. Maybe it's something you can look into as dissapointment in the lack of such features mentioned in the manual can lead to complaint. Not from me though I'm a little smarter than that :p
Anyways I am so pleaeed with this version I am upgrading as soon as my grant comes in. I want to make the best of all the features I can get from this nifty package.
