COLOR PICKER/EYEDROPPER
What I'd REALLY like in AS is a COLOR PICKER. I get tired of switching between Photoshop, copying the colour code for a colour I want, then going back to AS, opening the color menu, and pasting the code in there.
Instead, a simple EYEDROPPER tool is almost a MUST HAVE ITEM for the software.
Is there a separate script for this?
In the meantime, try GetColor You can quickly copy RGB codes to the clipboard, and then Ctrl-V into Anime Studio's colour thing. Brilliant!
J
J
- Víctor Paredes
RGB 8 bit hex value. Paste into the # box of AS Color picker, and delete the starting "# and ending " characters, so you get something like
Another (quick and dirty) method in Mac OS X is to take a screenshot in PNG and import that as a custom swatch image into AS. Then you can pick your colors as you like it. If you have trouble selecting the correct pixel, magnify the screen, either with Command Option + combo, or (under OS X 10.4.8 ) using the scroll wheel in combination with the Control key. Of course, you need to enable Universal Access in System Preferences for screen magnification to work.
FFCCFF-
Thunderone
Cpick it's a great tool too, for windows.
http://home.hccnet.nl/s.j.francke/software/software.htm
http://www.snapfiles.com/get/cpick.html
-No es el lápiz, si no lo que hagas con él.-
- It's not the pencil, it's what you do with it!.-
