Scaling of imported images
moorsel
Post by moorsel »
I created an anme file and made the mistake to initially work with the default project settings (320x240 pixels). When working with defaults I created some image layers and rescaled the images (they were to large and had to fit onto the screen). All images were placed in a group layer and the scaling was done at the lever of this group layer.
After a while I discovered my mistake and changed the defaults to PAL. When I add new image layers to the group layer, these images are scaled differently. for now my work around is to set the project settings back to web, create the image layer by importing the image, place this image layer into the grouping layer on which the scaling is done and restore the project settings back to PAL. Isn't there a better way to deal with this?
Gr,
Frank
rylleman
Post by rylleman »
This is a bug.
Also if you open the properties for one of the old layers, from before you changed the project size, these will change their scale.
Mikdog
Post by Mikdog »
oops
