snow tutorial
touchdown
snow tutorial
Post by touchdown »
Does anyone have a good tutorial for making snow?
I'm trying to make a subtle snowfall scene, not a snow storm.
Slow falling, large coverage, blurred.
Any takers?
Thanks.
DK
Post by DK »
Have you seen the snow script in AS under the "scripts" menu?
D.K
touchdown
Post by touchdown »
Hey thanks.
New to the program, that's all. The help file could use a little polishing to point to some things too.
Is there a trick to getting shapes to fill properly? I've used the tutorial, pressed "spacebar" and it's a hit or miss when I get the "you are trying to make a new shape....".
Sometimes either works (yes or no) to fill properly.
I must be missing something basic.
Mikdog
Post by Mikdog »
He he.
Shapes takes some getting used to. Will have you pulling your hair out.
Good luck. Once you understand it, it will make sense completely.
Like, think of a balloon (outline) It can only be filled with water (color) if the balloon is CLOSED without holes.
That might not help, good luck.
