Layer has no keyframe at zero, they moved and won't go back
touchdown
Post by touchdown »
I've got a vector layer that has a simple shape in it. Somehow the origin keyframes have moved six frames out. I can't get them back.
Is there a way to reset a keyfram back to zero?
copy and paste keyframes could fix it.
are you sure you created the layer at frame zero?
are you sure you draw the shape in frame zero?
remeber the layer will be visible since the frame in which you created it. the same happens with shapes.
touchdown
Post by touchdown »
yeah i think i was accidentally at frame 6 when it was made.
is there anyway to get that back to frame 0?
or can i remove frames 1 through 5 of everything (just static shapes waiting to be animated) to catch up to frame 6?
you can select the keyframes you want in frame 6, go to frame zero, copy, paste and then delete the keyframes in frame 6 (using the buttoms of timeline).
another option is, being at frame 6, go up to
Animation>Copy current frame...
then select Copy entire document, to the frame zero.
(remember after you must delete the keyframes in frame 6 too)
touchdown
Post by touchdown »
Ahh, very clever. worked fine so far.
If i lose my project I'm blaming you! 8)
Rasheed
Post by Rasheed »
touchdown wrote:If i lose my project I'm blaming you! 8)
:shock: That is not very cool to write. I'm sure you meant to use the irony emoticon ( ;) )
Anyways, always backup your project if you're not sure it will survive your manipulations, e.g. by saving it under a different name, like "bu_project.anme". You can always delete it afterwards. Better safe than sorry.
Rasheed wrote: :shock: That is not very cool to write. I'm sure you meant to use the irony emoticon ( ;) )
maybe it was a cool irony... or maybe is a new way to use emoticons, maybe now emoticons, as words, have a lot of semantic contents
Guys, guys, handbags at dawn! Let's confine bitching to things that matter!
touchdown
Post by touchdown »
jahnocli wrote:Guys, guys, handbags at dawn! Let's confine bitching to things that matter!
thank you for the sanity check.
Selgin and I have traded a few pm's on some issues. I think if he found my choice of emoticon distasteful he would've said something.
As a precautionary measure I shall now include a footnoted annotation of all my graphically represented post-related emotions :oops: *1
*1 (this means I'm thrilled at our level of internet sensitivity appreciation)
:lol: *2
*2 (and that meant I was joking) :wink: *3
*3 (and that hopes you caught the light-hearted sarcasm)
Handbags at dawn? heh, i like that.
Seriously though, (i wasn't actually going to blame him).
