Position Control Bone - Across separate skeleton-layers
appelgurk
Post by appelgurk »
I have two characters in separate skeleton-layers. One character is supposed to carry the other one in his arms. So I want to transfer the translation of the first character's pelvis-bone to the other.
Apparently there is no way to make constraints across separated bone-layers (or sub bone-layers).
Does anyone have a suggestion of how to solve this without having to manually keyframe the other character?
I have tried to rig both characters in the same bone-skeleton with this structure:
root
--rootBoneChar1
--pelvisBoneChar1
--rootBoneChar2
--pelvisBoneChar2
Then pelvisBoneChar1 is used as Position Control Bone for pelvisBoneChar2. This works great. However, this makes it impossible to scale and otherwise manipulate the characters separately.
I then put the characters into two Group-layers. But then all bind layer/points information is gone and the icons for binding layers and points are greyed out when the grouped layers are selected.
/Appl
Have you readed this post?
http://www.lostmarble.com/forum/viewtopic.php?t=3465
Perhaps it could help you.
Good Luck!
