Scripting help needed
ingie01
Post by ingie01 »
I just purchased ASP for the iMac. I would like to know how to install Fazik's tool scripts for this OS X ?
Do I need scripts written for the Mac?
I've become so dependent on these tools on my Intel machine I NEED them on my mac machine.
You'll know when you get there! My Dad
Rasheed
Post by Rasheed »
If Anime Studio Pro is installed in the standard location (which should be the case if you installed normally), the ASP folder should be located in the Anime Studio Pro folder of the Applications folder. Find the scripts sub folder in there, then the tool sub folder thereof (see screenshot)
I have the Dutch localized version, so Applications read Programma's.
Just unzip Fazek's zip archive (this will create folder). Drag all the files in that folder to the tools folder. I hope that is a clear enough description.
ingie01
Post by ingie01 »
Thanks Rasheed,
Just needed moral support, but haven't attempted that as yet.
ingie01
Post by ingie01 »
I did the unzipping then the folder contents into existing tool file. When I open AnimeStudioPro I see one little box at the end of tool with a x through it. No luck! I don't know how to attatch a screen shot as well..............grrrrrr.[/img]
Rasheed
Post by Rasheed »
How to upload a screenshot to this forum on the Mac
Press and hold down the Command and Shift key, press the 3 key, and release all keys on your keyboard to create a screenshot file. This screenshot will be located on your desktop and can be uploaded to an image sharing site, like imageshack.us.
Open your web browser and navigate the the imageshack.us website. Click on the button "Select file", select the screenshot file on your desktop, and click on the "Select" button in the file dialogue box. Now, back on the imageshack site, click on the "host it!" button. Now, the window will be updated with all kinds of text fields. Click inside the text field that is labeled "Thumbnail for forums (1)" (second text field from the top of the page), and copy with Command C (Press and hold the Command key, press the C key, and release both keys).
Next, go to this forum, create a message, and click the Image
the Command key
the Shift key
ingie01
Post by ingie01 »
I'll try this again. Many thanks for your Personalized Service.
(I've recently been in and out of doctor's offices and haven't been able to work on any projects hence my slow replys.)
