Smoother Curves?
gtcable
Smoother Curves?
Post by gtcable »
I've been trying to build a curvy stick figure type of character. I'm having trouble with Anime Studio Pro making my curves kinda rounded hinge points instead of a nice smooth curve. (see attached GIF).
Is getting a smooth curve even possible with a multi-point character? If I'm required to use 5 points in a single leg is it not possible to make it look like one smooth curve?
Why do you need 5 points?
A curve like that would be smooth with just 3 points. And it would still have a wide range of motion.
Depends on if you need sharp bends at the joints. Using the curve tool you can animate the "curviness" of the spline at a point if needed.
If in smoothness you mean that sort of "lumpyness" from changing the width of a stroke... er... no. Not much can be done about that. It is sort of the nature of the beast.
If you peak the ends of a spline the curves and varied width strokes look a little better.
Forgive this silly and totally pointless animation. Was trying to interprete your sample image. ;)
http://www.lowrestv.com/moho_stuff/curvy.mov
gtcable
Post by gtcable »
Well three vector points isn't going to give you foot control, or look like he has a knee. :roll:
All the same I think you answered my question. This is just one of the limitations of the software. I'll just deal with it.
Thanks.
